AB 800's with Cyber Sync's(battery operated) repeatedly
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=455
Author:  llpoolej [ Sun Apr 11, 2010 10:31 pm ]
Post subject:  AB 800's with Cyber Sync's(battery operated) repeatedly
firing. It happens on the light I have the trigger on, so, I pretty much am guessing it is the cybersyncs. Anything I can do to fix it without sending them in? I am pretty busy at the moment and really need triggers(and lights that work :) )
Author:  Technical Support [ Mon Apr 12, 2010 10:41 am ]
Post subject:  Re: AB 800's with Cyber Sync's(battery operated) repeatedly
it sounds like a low battery in the transmitter. Press the test button on the transmitter, if you get multiple blinks, the battery is getting low, if you get no blinks, the battery is virtually dead. One blink, the battery should be OK. If you remove the battery during one of the rapid fire coniptions, and the firing stops, you can bet it is the battery. They run about $4 and are available at WalMart, Radio Shack, Walgreens, and other retailers.
