| VLX with Ultra 1800 White Lighting http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4551 |
| Author: | tomegenes [ Thu Aug 28, 2014 5:23 pm ] |
| Post subject: | VLX with Ultra 1800 White Lighting |
Will the ultra 1800 white lighting work with the VLX vagabond extreme and how long to recycle at full power |
| Author: | Luap [ Thu Aug 28, 2014 5:31 pm ] |
| Post subject: | Re: VLX with Ultra 1800 White Lighting |
Yes. Recycle should be about the same as from powerline - under 4 seconds. |
| Author: | Mack [ Fri Aug 29, 2014 8:08 am ] |
I use a pair of them in the Vagabond-Mini without an issue. I would recommend unscrewing the modeling light else it might flicker a bit at times. They do seem to run all day without an issue, maybe 400 shots (If I use one Vagabond-Mini per head) which is surprising given the Mini's size. I usually run 5 heads off two Mini units on location. Extreme would be nicer and a better mounting bracket too it appears. The Mini's bracket and me never get along and I'm surprised I haven't snapped it off yet too. Mack |
| Author: | samplin [ Fri Sep 05, 2014 11:15 pm ] |
Luap wrote: Yes. Recycle should be about the same as from powerline - under 4 seconds. What should be the recycle time for the The White Lightning™ X3200 on Full power with the VLX ? |
| Author: | Technical Support [ Mon Sep 08, 2014 9:39 am ] |
1 X3200 would recycle in 4 seconds, the same as in a wall outlet. |
