| Question for Administrator: Searching the Board? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4595 |
| Author: | gerard_dirks [ Fri Oct 03, 2014 4:51 am ] |
| Post subject: | Question for Administrator: Searching the Board? |
Hello I have some problem with using the board. When I tried the Search function of the board I got no answer. In this case I want to know all what was written about the Cyber Commander as using them as Flash Meter So my key words are: "cyber commander flash meter" and the answer was, "The following words in your search query were ignored because they are too common words: meter commander cyber flash. You must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 14 characters excluding wildcards" Is it possible that the Indexing of the board is not working? Regards Gérard |
| Author: | Technical Support [ Fri Oct 03, 2014 10:35 am ] |
| Post subject: | Re: Question for Administrator: Searching the Board? |
It is probable there are so many posts in regards to Cyber Commander Flash meter, that that particular combination is too common to yeild a search. You can try searching "cyber commander"+"flashmeter", including the quotes, or feel free to ask the question, even if it has already been asked. |
