Flash Meter of the Cyber Commander
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4598
Author:  gerard_dirks [ Fri Oct 03, 2014 10:11 am ]
Post subject:  Flash Meter of the Cyber Commander
Hello
I read the manual of the Cyber Commander a couple of times, but I don't know it I can use the Flash Meter of the Cyber Commander as a Flash Meter for speedlites. (my native language is not englisch :-(
I tried a couple of situations on a free channel to measure the flash of the speedlites but no value appears. In this forum I haven't found any answer to this possibility.
A normal flash meter goes in a wait modus for the flash and as soon as the flash releases the f-value appears. I have no idea ho the CC act, because I can't release a Speedlite with the Test-Button of the CC
Regards
Gérard
Author:  Technical Support [ Fri Oct 03, 2014 11:11 am ]
Post subject:  Re: Flash Meter of the Cyber Commander
If a speedlight fires when a meter reading is being taken, then the CC will meter the flash. The CC does not have a mode where it waits for a flash, like a mainstream flash meter.
You can use a CSRB+ to trigger the speedlight and get metering, triggering and grouping functions.
