| Cyber Commander "Low Battery" warning http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4612 |
| Author: | John Isner [ Mon Oct 20, 2014 8:46 pm ] |
| Post subject: | Cyber Commander "Low Battery" warning |
I recently purchased the Cyber system to work with my Alien Bees. I have used the system successfully for a few weeks. Today the Cyber Commander flashed "Low Battery" and would not let me toggle a refresh. I assumed the message referred to the Cyber Commander's OWN batteries, so I replaced them. However I still get the warning. Does it mean that the batteries need replacing in one or more of the Cyber Sync units? If so, how do I know which one? |
| Author: | John Isner [ Mon Oct 20, 2014 9:02 pm ] |
| Post subject: | Re: Cyber Commander "Low Battery" warning |
Oops, I BOUGHT the new batteries, but I did not actually replace the old ones with the new ones. Now it's working just fine. |
| Author: | Technical Support [ Tue Oct 21, 2014 8:54 am ] |
Since you asked, sort of, how to tell when the receiver batteries are low; the receiver's LED will blink red once in response to a trigger command (either the CC, CST, or its own test button) if the battery is good. The LED will blink multiple times in response to a trigger command when the battery is low. You would not be able to tell via the CC directly. |
