| Orange Light on original Vagabond http://paulcbuff-techforum.com/viewtopic.php?f=8&t=463 |
| Author: | pixelpix [ Wed Apr 14, 2010 12:30 pm ] |
| Post subject: | Orange Light on original Vagabond |
Does the orange light on the Vagabond (1st generation) mean that the battery is no good and needs to be replaced? Thanks |
| Author: | Technical Support [ Wed Apr 14, 2010 2:16 pm ] |
| Post subject: | Re: Orange Light on original Vagabond |
The orange light means there is not sufficient charge in teh battery to run the inverters at that particular load. If the batteries should be fully charged and you still get that light, then yes, the battery is likely in need of replacement. |
| Author: | pixelpix [ Wed Apr 14, 2010 2:26 pm ] |
The green charge light went on, but when I switched on the unit there was a steady orange light. I guess time for a new battery. Thanks |
