Light fires when I focus instead of when I take the photo
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4645
Author:  lily5lace [ Sun Nov 23, 2014 5:59 pm ]
Post subject:  Light fires when I focus instead of when I take the photo
I'm using a Vello flash trigger with a b800, and cannot make it work! I got a mono adapter so that the cord would work, but now, testing it, I'm finding that the light is firing when I press the shutter halfway in order to focus, rather than when I actually take the photo. Or rather, I should say that it only fires when the shutter button is halfway pressed-- if I skip that step entirely, it does not fire at all. Obviously, that makes it completely useless. Does anyone have even the slightest clue why it's doing this? Because I'm at a loss....
Amanda
Update: I have since used the cord from the Vello trigger to plug the b800 directly into my camera (a Canon Rebel T3, for reference) which does not have a PC port. Even connecting the light directly to my camera, it still only fires when the shutter is pressed halfway.
Author:  Technical Support [ Mon Nov 24, 2014 10:25 am ]
Post subject:  Re: Light fires when I focus instead of when I take the phot
How are you plugging into the camera, since it has no PC port? Are you using the 1/8 jack on the side of the camera in any of the configurations?
Author:  craig16229 [ Sun Nov 30, 2014 11:21 am ]
Amanda
That almost sounds like the focus assist beam from your body is setting off the B800 via optical slave.
CraĆ­g
http://www.craigwasselphotoart.com
