| Taking apart a White Lightning Ultra (1200) http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4655 |
| Author: | buddhadude [ Mon Dec 08, 2014 2:37 am ] |
| Post subject: | Taking apart a White Lightning Ultra (1200) |
I'm in a bit of a bind.. I've had my trusty white lightning 1200's for a while, though I've barely used them since I haven't been able to keep up with photography. I've recently gotten back into it, and these lights are great - amazing lights. Everything was fine until I let my son use them (mistake #1). He thought the slave light was a button and managed to push it in, not breaking it, but pushing it inside the frame. I can see, and I thought I'd be able to unscrew the back end with the on/off switches, pull it out a bit and adjust it. (mistake #2) Needless to say that doesn't work that way, and I've unscrewed the 2 screws around where the power plug goes. I've realized that they are screwed in from the inside out, and I have the 2 little gears for the screws - but I need to open up the entire fixture. It's extremely simple, only you can only do it from inside. I see screws on the body of the white lightning, and just wondering if there were anymore surprises in store before I take it apart. Any help is greatly appreciated! |
| Author: | Technical Support [ Mon Dec 08, 2014 10:42 am ] |
| Post subject: | Re: Taking apart a White Lightning Ultra (1200) |
Due to the risk of high voltage inside the flash, we cannot recommend opening our flash units. I would recommend contacting our repair department to see what the charge would be to repair the light. Alternatively, peanut slaves can be purchased to plug into the 1/4" jack on the back of the light. We recommend FlashZebra.com for items such as this. |
