Wed Apr 14, 2010 12:30 pm
Does the orange light on the Vagabond (1st generation) mean that the battery is no good and needs to be replaced? Thanks
Wed Apr 14, 2010 2:16 pm
The orange light means there is not sufficient charge in teh battery to run the inverters at that particular load. If the batteries should be fully charged and you still get that light, then yes, the battery is likely in need of replacement.
Wed Apr 14, 2010 2:26 pm
The green charge light went on, but when I switched on the unit there was a steady orange light. I guess time for a new battery.
Users browsing this forum: No registered users and 7 guests
