| cyber commander sequence http://paulcbuff-techforum.com/viewtopic.php?f=8&t=477 |
| Author: | Moby [ Sat Apr 17, 2010 12:44 pm ] |
| Post subject: | cyber commander sequence |
I think I understand the startup sequence. But what happens if say, I raise a light and the power cord pulls out, do I have to unplug all the lights and redo the startup sequence or just do it for that light or do I just plug it back in without regard to sequence |
| Author: | rms956 [ Sat Apr 17, 2010 1:40 pm ] |
| Post subject: | Re: cyber commander sequence |
If you mean hook-up sequence, I have had no problems with unplugged power from the lights as long as the RJ-11 remote line is still plugged into the receiver and the light. I'm not sure if the new firmware 29v. with it's refresh feature added to CC has done away with performing that seqence. RMS |
| Author: | Luap [ Sat Apr 17, 2010 8:07 pm ] |
Unplugging a light will not change the CC or the CSRB settings. Just plug it back in and everything should be where you left off. |
| Author: | Moby [ Mon Apr 19, 2010 6:55 pm ] |
Thank you both. :D |
