Sun Jun 07, 2015 11:45 pm
Any reason why its not seeing. Only a few feet away from another PCB light. Not hidden as I can see flash right behind it.
Mon Jun 08, 2015 9:34 am
Do you have anything plugged into the sync jack? If so, this will lock out the slave eye.
Does it see if a flash is fired directly into the back panel?
How much ambient light is present, and does the response improve if the ambient light is lowered?
Mon Jun 08, 2015 9:50 am
Oops, doubled checked sync cable. Thought I had taken it out. It sees, how wonderful!
Users browsing this forum: Google [Bot] and 42 guests
