Possible Electrical "Leak" http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4817 |
Author: | jkilgo [ Mon Aug 17, 2015 1:43 pm ] |
Post subject: | Possible Electrical "Leak" |
I have two White Lightning X1600 Flash Units and on X800 I purchased these used over a year ago. I really love using them and they function very well even though I am not sure of the age these units. My only problem is that recently I noticed what I think might be an electrical leak from one of the X1600 units. I first noticed this when I grabbed the light stand that it was attached too and as I slide my hand down the pole I noticed what felt like a slight vibration on my hand. I then lightly press my fingers against the metal portion of the unit and slide my fingers across the surface and felt the same sensation. I quickly went to the other X1600 and the X800 and repeated the same steps and I did not feel any such thing. I have used it once more since discovering this but I am a little hesitant for safety reasons to continue it's use. I do need this third light. Am I nuts or is this a possible slight electrical issue? TIA -Jim |
Author: | Technical Support [ Mon Aug 17, 2015 4:51 pm ] |
Post subject: | Re: Possible Electrical "Leak" |
This sounds like a bad ground in the electrical system. Make sure you are using a properly grounded (three prong) outlet (try using a different outlet as well). Remove any extension cords, and if necessary, try exchanging the power cord with a different light. If this cannot be resolved by using different power cords or outlet, you should contact Customer Service for more trouble shooting. |
Author: | jkilgo [ Thu Aug 20, 2015 2:21 pm ] |
Thank you! I am contacting CS to see about repair. Jim :D |
Page 1 of 1 | All times are UTC - 6 hours [ DST ] |
