CyberSync / AB1600 - Bad Ground? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4818 |
Author: | skidz7 [ Mon Aug 17, 2015 3:51 pm ] |
Post subject: | CyberSync / AB1600 - Bad Ground? |
Equipment: Einstein with Cybersync Transciever AB1600 With CSR+ (AC-powered Cybersync+ receiver) Sometimes when working outdoor events I'll get a client-supplied power feed (usually from a generator) that has a ground issue. This causes issues with the CS+/AB1600. The Einstein doesn't seem to care about the ground and still works fine. The only way the AB works is if I unplug the CS+ receiver. Does anyone know whether the battery-powered CyberSync+ receiver will work in this situation? |
Author: | Technical Support [ Mon Aug 17, 2015 4:53 pm ] |
Post subject: | Re: CyberSync / AB1600 - Bad Ground? |
CSRB+ receivers can be a little more tolerant of grounding issues, but are not immune, and grounding may not be the issue at hand. What characteristics are you seeing when having problems? |
Author: | skidz7 [ Tue Aug 18, 2015 5:57 pm ] |
Technical Support wrote: What characteristics are you seeing when having problems? The AB isn't triggered by the Cybersync Receiver, even when pressing the test button directly on the receiver itself. I assumed it to be a ground (or some type of electrical) issue. A couple of my power strips actually have LEDs that indicate if there's a non-working ground and that was showing a problem the last time this happened. In one case the only change I made was moving to another circuit (with a good ground) and the problem went away. The Einstein seems immune to such issues though, or at least it has been for me so far. |
Author: | Technical Support [ Tue Aug 18, 2015 8:44 pm ] |
Failure to fire via the RJ11 cable is possible with a bad ground, so that is the likely problem. |
Author: | skidz7 [ Thu Aug 20, 2015 2:41 pm ] |
Technical Support wrote: Failure to fire via the RJ11 cable is possible with a bad ground, so that is the likely problem. I decided to experiment a bit. I tried running power without ground through both and it wouldn't fire. (expected) I then tried plugging the flash and the receiver into separate power feeds. One with a ground and one without. Regardless of the configuration, if either the flash or the receiver had a faulty ground the flash wouldn't trigger when the RJ11 was connected. I'm wondering if anyone with a CSRB+ has (or would) try this to see whether it behaves the same way. |
Author: | Technical Support [ Fri Aug 21, 2015 12:38 pm ] |
The CSRB+ receiver would not be grounded in the same way as an AC power receiver. This leaves the light to have or not have a proper ground. I have seen the problem persist when using a CSRB+, as well as being remedied by using a CSRB+. Much of will have to do with the nature of the problem and the specific tolerance of a given light. Someone else's experiment may not match your results. |
Page 1 of 1 | All times are UTC - 6 hours [ DST ] |
