The constant flashing is indicative of a bad ground. Most likely, it is in the power supply chain of the light that starts the acting up.
This could be the circuit, the outlet (even if only one socket on the outlet), any extension cord or power strip in use (even of another light works fine on it), the power cord to the light, or possibly even the power cord captive to the CSR+. The RJ11 telephone cord may also be at play.
We generally recommend removing any extension cords and power strips for the purposes of trouble shooting and verifying if the problem persists. Then changing outlets, then changing power cords, then swapping the telephone cords. It doesn't really matter what order you do this, but do one item at a time to isolate which is the problem. Swapping items out with a light that is working correctly can help isolate a problem.
Also, inspect the "remote" ports on the light and the receiver. There should be four gold-ish colored contacts, and they should be evenly spaced and at the same height. The telephone cord should also fit snugly, and the retainer clip should be functioning. If the plug is loose, then dysfunction can occur.
