Einstein with High Speed Sync upgrade?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4829
Author:  korayust [ Tue Sep 15, 2015 11:36 am ]
Post subject:  Einstein with High Speed Sync upgrade?
Hi,
I would like to know if you have any plan to offer High Speed Sync support on current or maybe upcoming model of Einstein?
Thanks in advance.
Koray
Author:  Technical Support [ Tue Sep 15, 2015 2:49 pm ]
Post subject:  Re: Einstein with High Speed Sync upgrade?
Not currently. HSS requires communication with the specific camera used, so it would require far more than just a firmware upgrade. Additionally, the hardware within the Einstein would not support proper HSS, even if there was a communications path.
Author:  korayust [ Tue Sep 15, 2015 3:58 pm ]
Thank you very much for your quick (as always) reply.
This is why I love and use p.c.buff stuff.
All the best wishes from North Cyprus :)
Author:  Keano12 [ Wed Dec 23, 2015 5:55 pm ]
Does the same answer apply to TTL?
Author:  Technical Support [ Fri Dec 25, 2015 11:06 pm ]
Yes, then some calculation programming.
