| new optional heavy duty VML bracket!!! http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4840 |
| Author: | Technical Support [ Thu Sep 24, 2015 1:54 pm ] |
| Post subject: | new optional heavy duty VML bracket!!! |
We are ready to ship a new bracket designed to securely hold your Vagabond Mini Lithium to your lightstand, even while on the move. There are two pieces, a bracket and a clamp. You can purchase the pieces as a set, or individually, for those of you who already have a component (notably, a suitable clamp) The set can be found here: http://www.paulcbuff.com/vmbrkt-set.php The individual pieces can be found on this page: http://www.paulcbuff.com/mountingblocks.php ![]()
| Author: | Planet [ Sat Sep 26, 2015 10:39 am ] |
| Post subject: | Re: new optional heavy duty VML bracket!!! |
And there was much rejoicing!!! |
| Author: | jbr51 [ Thu Oct 01, 2015 10:22 pm ] |
The arrives with tab shows the wrong product. |
| Author: | Technical Support [ Thu Oct 01, 2015 10:38 pm ] |
Indeed it does! I will get with our web team ASAP. Thanks! |
| Author: | Keano12 [ Fri Dec 11, 2015 3:02 pm ] |
will this work on most light stands? I use impact light stands. No jiggles or wobbles? |
| Author: | Technical Support [ Fri Dec 11, 2015 4:29 pm ] |
This uses the same metal mounting block as current AlienBees and Einstein lights. It tightens down snugly on 5/8" studs and the bracket is snug on the mount. |
