| vagabond mini lithium http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4858 |
| Author: | lesprit [ Fri Oct 09, 2015 10:48 am ] |
| Post subject: | vagabond mini lithium |
Hi, I have a vagabond mini lithium with a tension problem. It is a 220V model and with a fully charged battery, it does not work. With a multimeter it gives only 35 volts. thank for your help. |
| Author: | Technical Support [ Fri Oct 09, 2015 2:24 pm ] |
| Post subject: | Re: vagabond mini lithium |
That is an internal fault which will require the inverter portion to come in for repair. Please contact our repair department for specifics on how to return the item for repair. repair@paulcbuff.com |
