Fri Oct 16, 2015 1:00 am
Connected a Einstein to my VML, it turns on but the flash doesn't fire.
when connecting the flash to AC it works.
looks like the VML isn't outputting enough power .
is that possible?
do i have to send it in for repair? (second time! :( )
Yitzy Russek
Fri Oct 16, 2015 8:49 am
Are you getting the green "ready" indicator on the flash?
It is possible to not output the correct voltage. If you have a multimeter, you can check this. It should be around 230VAC.
Sun Oct 18, 2015 6:42 am
Tried again and it wouldn't even power up the flash.
the screen turned on for a second and turned right off.
don't have a multimeter..
guess will send it in.
Yitzy
Users browsing this forum: No registered users and 7 guests
