| VML not powering Einstien http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4863 |
| Author: | yitzy [ Fri Oct 16, 2015 1:00 am ] |
| Post subject: | VML not powering Einstien |
Connected a Einstein to my VML, it turns on but the flash doesn't fire. when connecting the flash to AC it works. looks like the VML isn't outputting enough power . is that possible? do i have to send it in for repair? (second time! :( ) Yitzy Russek |
| Author: | Technical Support [ Fri Oct 16, 2015 8:49 am ] |
| Post subject: | Re: VML not powering Einstien |
Are you getting the green "ready" indicator on the flash? It is possible to not output the correct voltage. If you have a multimeter, you can check this. It should be around 230VAC. |
| Author: | yitzy [ Sun Oct 18, 2015 6:42 am ] |
Tried again and it wouldn't even power up the flash. the screen turned on for a second and turned right off. don't have a multimeter.. guess will send it in. Yitzy |
