| Canon 600 EX-rt http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4881 |
| Author: | mavryder [ Fri Dec 11, 2015 10:01 am ] |
| Post subject: | Canon 600 EX-rt |
I have a cybercommander and two Einsteins. I was wondering if the cybercommander could trigger the 600EX-RT along side the Einsteins. My apology if the question has been asked before I did search the discussions and find nothing relevant. |
| Author: | Technical Support [ Fri Dec 11, 2015 12:40 pm ] |
| Post subject: | Re: Canon 600 EX-rt |
The CyberSync system will not work directly with the radio functions of the Canon RT radio system. You may purchase CyberSync CSRB+ receivers and plug them into the 600RT flash units and get them to fire. You can also meter and group them, but you would not be able contol flash power. |
| Author: | mavryder [ Sat Dec 12, 2015 9:39 am ] |
Technical Support wrote: The CyberSync system will not work directly with the radio functions of the Canon RT radio system. You may purchase CyberSync CSRB+ receivers and plug them into the 600RT flash units and get them to fire. You can also meter and group them, but you would not be able contol flash power. Thank you very much for you reply! If I use the CSRB + receiver plugged into the Speedlite can I control flash power with the cybercommander ? |
| Author: | Technical Support [ Mon Dec 14, 2015 10:16 am ] |
No. Only triggering, grouping, and metering functions (really all of these are related to triggering) are available with non-Buff lights. |
