| 11" Reflector and 30 degree grid http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4888 |
| Author: | bsphoto [ Mon Jan 04, 2016 1:18 pm ] |
| Post subject: | 11" Reflector and 30 degree grid |
I was looking at the 11" Long throw reflector for a shoot at the end of the month and was checking out grids for it. I see you have a 30 degree grid, but the spread of the reflector alone is 28 degrees. The specs on the grid say "narrows the beam spread from 28° to 30°" Can somebody explain how this works? Maybe post an example with and without the grid? Thanks Oh wait, I found my answer: viewtopic.php?f=8&t=2500 Never mind! |
| Author: | Technical Support [ Mon Jan 04, 2016 5:21 pm ] |
| Post subject: | Re: 11" Reflector and 30 degree grid |
I will say the text you reference is confusing, so we made the update to more accurate text. Thanks for bringing this up! |
| Author: | bsphoto [ Tue Jan 19, 2016 1:44 pm ] |
Thanks, that makes much more sense. |
