| Einstein spontaneously increases its power level http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4890 |
| Author: | nogreymatter [ Wed Jan 06, 2016 8:51 pm ] |
| Post subject: | Einstein spontaneously increases its power level |
I've been experiencing a phenomenon where an Einstein will suddenly jump up in power, causing overexposed images. I'm using a PocketWizard TTL5, and have the MC2 receivers in the sockets. I was wondering if the AC3 might be causing it, but it occurred tonight when I was just using the TTL5 without the AC3. Is it likely to be an issue with the remote or receivers, or the flash itself? |
| Author: | Technical Support [ Thu Jan 07, 2016 12:15 pm ] |
| Post subject: | Re: Einstein spontaneously increases its power level |
It is almost certainly a result of the remotes. However, we are not capable of properly diagnosing the PocketWizard system. I suggest giving LPA (PocketWizard) a call. 802-658-0038 x572 |
| Author: | nogreymatter [ Wed Jan 20, 2016 8:19 pm ] |
I believe it was actually a loose hotshoe on the camera itself! It had come loose before (the symptoms were unreliable triggering, which I blamed poor PocketWizard for until it got so bad it stopped firing altogether and then I noticed the tilting of the hotshoe), and I tightened it, but it came loose again. I didn't think of the hotshoe as a possible culprit for the power level changes, but it seems like it was probably (hopefully) the case. I just tightened it again with loctite for good measure. |
