| Einsteins not responding properly to cyber commander. http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4892 |
| Author: | captivatedman [ Sun Jan 17, 2016 1:48 pm ] |
| Post subject: | Einsteins not responding properly to cyber commander. |
Something strange stared happening with my cyber commander and Einsteins. I can only lower the flash power using the cc I cannot increase power settings. Any thoughts? |
| Author: | Technical Support [ Sun Jan 17, 2016 8:51 pm ] |
| Post subject: | Re: Einsteins not responding properly to cyber commander. |
it could be a button issue. go to the setup screen, then the flash meter screen, and open that. Try to push up on the left joystick and see if the ISO changes. |
| Author: | captivatedman [ Mon Jan 18, 2016 5:10 pm ] |
Technical Support wrote: it could be a button issue. go to the setup screen, then the flash meter screen, and open that. Try to push up on the left joystick and see if the ISO changes. That was it apparently. I have 2 CCs that probably need service what do I need to do? |
| Author: | Technical Support [ Mon Jan 18, 2016 5:25 pm ] |
If the up function is not working, there could be some debris stuck under the joystick preventing movement. Be sure to blow out or kind of dig/brush out from under it, then try again. For repairs, please visit this link for the full rundown: http://www.paulcbuff.com/repair.php |
