| Kelvin temp http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4921 |
| Author: | RodeoHammer [ Wed May 11, 2016 1:21 pm ] |
| Post subject: | Kelvin temp |
Would the Kelvin temp on the AB and White lightning be 5500? |
| Author: | spinningstill [ Wed May 11, 2016 3:31 pm ] |
| Post subject: | Re: Kelvin temp |
I believe the Einsteins are more geared toward constant white balance. |
| Author: | RodeoHammer [ Thu May 12, 2016 7:00 am ] |
I only have AB and lightening. I do know if you add some modifiers it will change the Kelvin temp mainly wondering about with out modifiers. |
| Author: | Technical Support [ Thu May 12, 2016 9:06 am ] |
The nominal color temp is 5600K at full power. As you reduce power, as with any Voltage controlled light, your color temperature will shift down by about 80K per stop. |
| Author: | RodeoHammer [ Thu May 12, 2016 11:25 am ] |
Thank you I wasn't too far off in my thinking. |
