| Einstein keeps turning off http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4931 |
| Author: | HotShot [ Sat Jun 11, 2016 6:30 pm ] |
| Post subject: | Einstein keeps turning off |
For some unknown reason, one of my units keep turning off. Is there anything I can do on my end to remedy this?
| Author: | Technical Support [ Sat Jun 11, 2016 9:28 pm ] |
| Post subject: | Re: Einstein keeps turning off |
Likely, it is a setting in a Cyber Commander, if you have one. If so, check this channel for a white dash under the graph (white matches the text for CH and Menu in the corners). If there a gray dash instead (gray matches the graph lines, and is hard to see), the channel is in standby. You can turn the light on, then go to OPEN MEMORY=> open from that channel (instead of STUDIO) Or You can go to SETUP=>Light Settings=> select POWER=> set to on from standby. If there is no Cyber Commander, let me know! |
| Author: | HotShot [ Tue Jun 14, 2016 11:05 am ] |
Thanks... yes, it was the setting on the CC. :D |
