| Einstien won't fire/flash http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4933 |
| Author: | Bjpender [ Wed Jul 06, 2016 8:44 am ] |
| Post subject: | Einstien won't fire/flash |
One of my four einstien units has stopped flashing. I took off the flash tube and checked it for charring on the contacts and there is no evidence of charring. I replaced the flash tube with a new flash tube and it flashed one time and then will not not flash anymore. The screen comes on and works and the audible alarm beeps every time I push the flash button on the back of the unit but the flash does not fire. Any thoughts on what the problem might be? Do I need to send the unit in for servicing? It has also stopped responding to the cyber-synch controller. |
| Author: | Technical Support [ Wed Jul 06, 2016 9:02 am ] |
| Post subject: | Re: Einstien won't fire/flash |
It could be a number of different thing, but they are all internal, considering you have already tried a new flash tube. This means the light will need to come in for repair. No RMA is required, and all of the pertinent information on repairs can be found here: http://www.paulcbuff.com/repair.php |
| Author: | Bjpender [ Wed Jul 06, 2016 9:30 am ] |
Ok. Thanks. Sending via UPS today. |
