Wed Sep 14, 2016 4:44 pm
I had 2 Alienbee 1600s, One of them suddenly stopped working and I wonder why. I turn it on and the OK green button flashed once and It doesn't light up. I hit the test button it wont fire. I turn it off and on try a few times and sometimes the green OK button will show up and if I hit the test fire button it fires then it died again. What went wrong. Do I need a repair
Thu Sep 15, 2016 9:13 am
How are you powering the light? Vagabond or AC mains outlet?
Is there anything plugged into the square telephone jack on the back? If so, remove it and see if the problem persists.
If using an AC mains outlet, and nothing in the telephone jack, then it sounds like a charging circuit issue which will require the light to come in for repair.
You can find more information on repairs here:
