| Cyber Commander - won't start after changing batteries http://paulcbuff-techforum.com/viewtopic.php?f=8&t=50 |
| Author: | AlanG [ Fri Dec 18, 2009 11:31 am ] |
| Post subject: | Cyber Commander - won't start after changing batteries |
When I change the batteries in the Cyber Commander, it won't come back on unless I remove the memory card and re-insert it. Sometimes I have to do this several times before the unit will activate. Is there something wrong or will this be corrected in the firmware? I also have the occasional freezing that you say will be corrected in a firmware update. |
| Author: | Technical Support [ Fri Dec 18, 2009 4:45 pm ] |
| Post subject: | Re: Cyber Commander - won't start after changing batteries |
both should be addressed in the firmware update and update process |
| Author: | jc11 [ Sat Dec 19, 2009 7:42 am ] |
Technical Support wrote: both should be addressed in the firmware update and update process And how would one get this update? |
| Author: | Technical Support [ Mon Dec 21, 2009 10:51 am ] |
We are working on that now. I will post either a new topic and/or individual replies when we are ready to release it. |
| Author: | svoelkel [ Mon Dec 21, 2009 2:59 pm ] |
If you decide to distribute the revised firmware via individual replies, please add me to the list. Thanks, Sam |
| Author: | bewally [ Wed Dec 23, 2009 2:05 pm ] |
Not working after battery change... FWIW had same issue ....pulled out memory card and put back in and Cyber Commander works fine... something to try.... it worked for me.... |
