Sat Aug 24, 2013 10:07 am
Hi -
Could you please tell me what amperage extension cord I should get to use with an Einstein in the UK (240 volts)?
How many amps does the Einstein draw?
Thank you,
-Rob
Mon Aug 26, 2013 9:44 am
In the U.S. we recommend a 12-14 gauge extension cord. This translates to a 1.63 to 2.05mm diameter wire (or 2.08 to 3.31 sq. mm).
Max amperage is 8-9A.
Mon Aug 26, 2013 9:49 am
Thank you.
Wed Jan 18, 2017 8:42 pm
I have both 12 and 14 50ft long 3-OUTLET extension cables rated at 300v. Is it safe to attach 3 Einsteins on either one? What are the limitations? Cheers!
Fri Jan 20, 2017 2:23 pm
using either should be fine. If given the choice, go with the bigger cord. There may be some slight reduction in recycle time.
