| Tips on Attaching Black Outer Cover to 86" PLM? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=5026 |
| Author: | jbuttonphoto [ Sun Feb 12, 2017 1:36 pm ] |
| Post subject: | Tips on Attaching Black Outer Cover to 86" PLM? |
I just purchased the 86" PLM and am having a hard time installing the black outer cover. It doesn't seem to be lining up with the umbrella. Anyone have any tips or tricks they found helpful when installing it? Thanks! |
| Author: | Technical Support [ Mon Feb 13, 2017 3:05 pm ] |
| Post subject: | Re: Tips on Attaching Black Outer Cover to 86" PLM? |
My way of doing this is to lay the cover over the collapsed PLM, then open it slightly. I then work my way around, one tip at a time, then fully open the PLM. Expect it to be a little tight, but if the ribs do not spread and position where they should, even by hand, then there may be something amiss. |
