| Vegabond II beeping noise when fully charged? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=503 |
| Author: | EventsbySPL [ Mon Apr 26, 2010 2:39 pm ] |
| Post subject: | Vegabond II beeping noise when fully charged? |
I just bought Vegabond II last week and i charged it for 12+ hrs and i was using it for the first time it worked fine for may be 30 to 40 shots 1/4 power only 1 AB800 plugged in and then suddenly it started beeping when i unplugged and plugged the AB800 in it and turned the light on. The red light kept blinking. Please help. Kunal Mehta |
| Author: | Technical Support [ Mon Apr 26, 2010 3:07 pm ] |
| Post subject: | Re: Vegabond II beeping noise when fully charged? |
The symptoms are consistent with a low battery. During the initial charge, was the cord securely seated in the charger? Did the red LED come on while charging? If not, retry the charge cycle and try again. If these did happen, the battery may be faulty. Please contact customer service to arrange for this to be corrected. |
| Author: | EventsbySPL [ Mon Apr 26, 2010 3:20 pm ] |
Thank you so much i will try the charge cycle again. And if it still happens i will contact customer service. This happened right when the bride walked down the aisle yesterday i saved my self with on camera 580EXii. I will try the charge cycle again. thank you for the quick response. Kunal |
