| Digibee 400 switch intermittent http://paulcbuff-techforum.com/viewtopic.php?f=8&t=5049 |
| Author: | Countbasel [ Mon Mar 20, 2017 9:45 pm ] |
| Post subject: | Digibee 400 switch intermittent |
I have a DB400 and after about 10 minutes of operation if I shut it off it will not come back on. I flip the on/off switch and the little light on the bee flickers and does not turn on. Also, the switch seems loose like a tripped breaker in a home breaker box. If I wait about 20 minutes it will come back on. Is there something related to temperature happening or maybe it's overheating? Thanks! |
| Author: | Technical Support [ Wed Mar 22, 2017 9:15 am ] |
| Post subject: | Re: Digibee 400 switch intermittent |
That would be a fault in the thermostatic spring inside the power switch. After it cools, it will switch over as expected. We can swap the power switch under warranty. http://www.paulcbuff.com/repair.php |
