| CC Spec Lights http://paulcbuff-techforum.com/viewtopic.php?f=8&t=5057 |
| Author: | mwoodbury [ Tue Apr 04, 2017 9:42 am ] |
| Post subject: | CC Spec Lights |
My CC cant find the Digi light ... Its not listed on the Identifying Lights setup screen ? I have 2 Digi's ... one is sean by the CC and the other isn't ?? |
| Author: | Technical Support [ Tue Apr 04, 2017 12:44 pm ] |
| Post subject: | Re: CC Spec Lights |
First, Make sure all items are on the same Frequency, and different channels. If you have both on Channel 1, for example, then only one channel will be displayed. Once you ensure everything is set to proper frequency and channel, enter the SETUP screen of the Cyber Commander. Do not go to spec lights, rather go to OPEN MEMORY, press in with the right joystick. With the left joystick, scroll to STUDIO. (the options here are <...SD49, SD50, Internal 1, Internal 2, STUDIO, CH1, CH2...SD1, SD2...>) Once at STUDIO, press in with the right joystick, and both lights should appear. You can now scroll right to the main screen. |
