| vagabond 2 with d2 from profoto http://paulcbuff-techforum.com/viewtopic.php?f=8&t=5077 |
| Author: | dron [ Sat May 13, 2017 4:00 pm ] |
| Post subject: | vagabond 2 with d2 from profoto |
Hi can vagabond II portable power drive d2 from profoto Profoto says d2 need 800 watt portable power. can vagabond II serve it ? |
| Author: | Technical Support [ Mon May 15, 2017 11:20 am ] |
| Post subject: | Re: vagabond 2 with d2 from profoto |
We have not tested the Profoto D2, so we cannot say for sure. Reports are the VMLs will not work, but we have not heard from VLX or VII users. |
| Author: | M. Bell [ Sun Jun 04, 2017 1:52 pm ] |
The Vagabond Lithium Extreme can power the Profoto D2. I had to update the latest firmware on the D2 for it to work. One thing to note, the D2 will shut off if using HSS above power level 9.2. |
| Author: | dron [ Wed Jun 21, 2017 3:04 pm ] |
Thanks for answer I have now tested vagabond 2 with profoto d2 it kann not power it. The Profoto do not go on. |
| Author: | Technical Support [ Wed Jun 21, 2017 5:07 pm ] |
Have you tried with the slow recycle mode? |
| Author: | dron [ Mon Jun 26, 2017 3:22 pm ] |
Hm I do not know now what mode was on slow or speed. It go not on and i have had scared it can destroy my d2 profoto. I can try again an then report you if you have interest Can i be sure that it will not destroy D2 profto flashstrobe? |
| Author: | Technical Support [ Wed Jun 28, 2017 10:12 am ] |
dron wrote: Can i be sure that it will not destroy D2 profto flashstrobe? It is unlikely to damage the flash, but I cannot speak in absolutes, as we have not done our own tests. I do not know of any claims where lights have been damaged use with a VII. |
| Author: | dron [ Wed Jun 28, 2017 10:57 am ] |
Hi now works all fine. I have updated D2 with new firmware and now there is an option to shoose recycling speed.(profoto says it shall be enable to use(weak external power packs). I can shoose between max speed,50% and 25 % recycling speed on d2. Now I tested 'Vagabond 2 with 25 % receicling speed on profoto d2. It work fine, ttl and hss all works, and hss at 100 % power level no trouble. It take about 1 or 1,5 second to recycling at voll power. now I can drive my two einstein with profoto togeter. I am happy to have a vagabond . thanks . |
| Author: | Technical Support [ Wed Jun 28, 2017 11:39 am ] |
Thanks for the feedback. I was unaware of the three options or the firmware update. |
