| Reflector coverage formula http://paulcbuff-techforum.com/viewtopic.php?f=8&t=5081 |
| Author: | RNPhotog [ Fri May 19, 2017 3:52 am ] |
| Post subject: | Reflector coverage formula |
Is there a formula for figuring out the coverage of the various reflectors? For example, the 11" reflectors coverage at 65 ft would be...? |
| Author: | Technical Support [ Fri May 19, 2017 9:15 am ] |
| Post subject: | Re: Reflector coverage formula |
If you need the actual formula, I can get that for you. If you need a close ball park, you can visit this link: http://www.paulcbuff.com/popups/grids/7_grid_chart.php This graph shows the beam spread of various grids when installed on a 7" reflector. The 11LTR is 28 degrees, so I would use the 30 degree zone for reference. As the distance doubles, so does the diameter. Yes, an 11" reflector would have a slightly larger area than the 7", but at 65 feet it is irrelevant (it would be a 4" difference at any distance). So at 65 feet, you are looking at a 40' spread. incidentally, at ISO100 and 640Ws, you are looking at f/5.6. |
