| charger and battery http://paulcbuff-techforum.com/viewtopic.php?f=8&t=5095 |
| Author: | myCAT190 [ Thu Jun 22, 2017 3:24 am ] |
| Post subject: | charger and battery |
I have the orange vagabond battery system. I'm getting a long beep and sometimes the flash will not work. If its the battery. Can I use the converter with the new VLX system. Or do I need to ditch the whole thing. I'm a little tired of lugging the weight around. Thanks, Aaron |
| Author: | Technical Support [ Thu Jun 22, 2017 9:31 am ] |
| Post subject: | Re: charger and battery |
The long beep is indicative of a low battery. A replacement battery would remedy this, and you can look for a 12220 style battery as a replacement. The VLX battery will not work for a variety of reasons, the main being it is a 25.6Vdc battery and the VII inverter has a 12Vdc input. |
| Author: | myCAT190 [ Sat Jun 24, 2017 12:29 pm ] |
Thanks |
