Fri May 07, 2010 10:53 pm
Hi,
I want to get AB400 to start my lighting setup and I wanted to get the wireless remote setup but its not clear if I but CyberSync Trigger Transmitter and CyberSync Battery Powered Trigger Receiver - Plus or if I also have to buy the
Cyber Commander?
If I have a small 10x13 room I have setup as my studio, will SB400 be enough if I am planning on using the Foldable Medium Octabox (35in.).
Thanks for any info or suggestions.
Sat May 08, 2010 12:32 am
I would suggest only the CST and CSR+ to start. If you build up your system to multiple lights you can always add the Cyber Commander and you will still put the CST to good use.
