| Einstein sizes http://paulcbuff-techforum.com/viewtopic.php?f=8&t=559 |
| Author: | charlesj68 [ Tue May 11, 2010 12:07 pm ] |
| Post subject: | Einstein sizes |
While I'm waiting for my number to come up and my Einstein units to ship, I am playing with solutions for how I'm going to pack stuff around. I'm leaning towards getting a Pelican case for the lights and certain accessories, but I need to know the dimensions of an Einstein to be able to figure out which cases make sense. How big are they? |
| Author: | Technical Support [ Tue May 11, 2010 12:15 pm ] |
| Post subject: | Re: Einstein sizes |
the housing is 4.8x4.8x5.7 withount any protrusions like mounting hardware or model lamps, etc. Overall demensions are 7.0 x 5.4 x 7.8. (all measurements in inches). the weight is 4 lbs, 5 oz, not inclusinve of the power cord. |
| Author: | tetrode [ Tue May 11, 2010 10:46 pm ] |
![]() Dave F. |
| Author: | charlesj68 [ Wed May 12, 2010 12:11 pm ] |
Great! Thanks. |
| Author: | Neuffy [ Thu May 13, 2010 5:11 pm ] |
Note that in theory you could replace the pyrex cap with a shorter one, as this one is longer than is strictly necessary. I may be doing that do save some room in one of my bags (they would be able to fit in a different orientation). |
| Author: | Technical Support [ Fri May 14, 2010 9:11 am ] |
Neuffy wrote: Note that in theory you could replace the pyrex cap with a shorter one, as this one is longer than is strictly necessary. not to be nitpicky, but i believe you mean Lexan instead of Pyrex. The shipping cover is Lexan, and if you can find a shorter one that fits, then yes. The dome is Pyrex, but it is at its minimal size. |
| Author: | Wil_Bloodworth [ Tue May 18, 2010 3:26 pm ] |
Neuffy wrote: Note that in theory you could replace the pyrex cap with a shorter one, as this one is longer than is strictly necessary. I may be doing that do save some room in one of my bags (they would be able to fit in a different orientation). Good idea! Technically, you can do that yourself. Just cut a horizontal section out and re-glue it back together without that section. I know it's a severe hack but it would work and save the room in the bag. - Wil |
| Author: | Neuffy [ Tue May 18, 2010 9:40 pm ] |
Technical Support wrote: Neuffy wrote: Note that in theory you could replace the pyrex cap with a shorter one, as this one is longer than is strictly necessary. not to be nitpicky, but i believe you mean Lexan instead of Pyrex. The shipping cover is Lexan, and if you can find a shorter one that fits, then yes. The dome is Pyrex, but it is at its minimal size. This is absolutely true. I have no idea why I typed "Pyrex" rather than the correct "Lexan". Not nitpicky at all. Thanks. |
