| White Lightning X1600 Overpowering the Sun/Vagabond 2? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=560 |
| Author: | ian510 [ Tue May 11, 2010 3:36 pm ] |
| Post subject: | White Lightning X1600 Overpowering the Sun/Vagabond 2? |
I am interested in getting a Vagabond 2 to use with one or more of my WLX units for outdoor daylight work. Is the WLX indeed strong enough to overpower the sun? Also, I have 3 WLX units. Would I be able to plug all of my WLX units into one Vagabond 2 or would it be better for me to get a Vagabond for each WLX unit? |
| Author: | Technical Support [ Tue May 11, 2010 4:05 pm ] |
| Post subject: | Re: White Lightning X1600 Overpowering the Sun/Vagabond 2? |
Whether or not the x1600 will overpower sun will depend on its distance from subject and modifier. If you have it in a 7' octabank at 20', then no. Using something likeo our HOBD at a reasonable distance will be fine. A softbox pretty close in could also do it. The VII will run all 3 lights at full power for 150-200 shots, and 5.5 second recycle times. one VII for each light will yield 2 sec recycle and about 600 shots. |
