Sat May 15, 2010 9:27 am
The positioning arm on one of ab800 does not have a very tight hold. What is the proper method for adjusting it so that it has a tighter grip? A see a screw on the handle but has a very skinny groove that standard flat heads don't seem to fit.
Thanks,
Jeff
Sat May 15, 2010 9:48 am
Don't mess with the screw, that can make a big mess. The handle is a ratcheting handle. If you tighten the handle as far as it will go before hitting the housing, pull out on the handle, disengaging the ratchet mechanism, and reposition it so you can continiue to tighten.
Sat May 15, 2010 10:52 am
Got it. Seems so simple you'd think you wouldn't have to explain it :)
Thanks,
Jeff
Users browsing this forum: Majestic-12 [Bot] and 13 guests
