Mon May 24, 2010 2:06 pm
Two of my white lightning Ultra 1200 brackets are slipping when using a 48" softbox.
The balsa is not gripping enough to avoid the rotation of the head.
I've tried to use a rubber washer instead without success.
What is the best way to repair this bracket?
Would the UMBA won't have this problem?
Tue May 25, 2010 10:36 am
The UMBA would be my recommendation. It is metal and is designed a little differently. Also, it includes a neoprene washer and a Belleville (metal) washer that is designed for more tension.
Users browsing this forum: No registered users and 78 guests
