| ultra bracket http://paulcbuff-techforum.com/viewtopic.php?f=8&t=597 |
| Author: | photopat [ Mon May 24, 2010 2:06 pm ] |
| Post subject: | ultra bracket |
Two of my white lightning Ultra 1200 brackets are slipping when using a 48" softbox. The balsa is not gripping enough to avoid the rotation of the head. I've tried to use a rubber washer instead without success. What is the best way to repair this bracket? Would the UMBA won't have this problem? |
| Author: | Technical Support [ Tue May 25, 2010 10:36 am ] |
| Post subject: | Re: ultra bracket |
The UMBA would be my recommendation. It is metal and is designed a little differently. Also, it includes a neoprene washer and a Belleville (metal) washer that is designed for more tension. |
