Fri May 28, 2010 5:42 pm
Is there a way when using the CC to have only the Channels that are connected and the groups that they in to show up in the lower left hand corner?
Its a pain to scan through all the channels and groups that are not being used.
If not I think it would a added benefit to the CC!!!!!
Which is an awesome device!!!! Throughly with my AB1600 and my CC!!!!
Thanks
DI Pro
Sat May 29, 2010 12:10 am
It's necessary to have all the channels and groups available to allow adding channels and groups. We tried to avoid the Japanese Watch syndrome where you have to go to the instruction book every time you want to do something. Anything can be programmed, but the more features you add the more complex it becomes to operate.
Tue Jun 01, 2010 8:23 pm
Yes but can't you have the software enable the channels and the groups assigned to the CC.
If I am only using 5 channels and 3 groups it is very cumbersome to scroll through the of the selections quickly when you are doing a shoot and need to male an adjustment in the settings.... I still say it would be beneficial than an hinderance.
Or at least make it a setting that enable the selection that the users can determine our own needs..
Thanks again
DI Pro
Users browsing this forum: No registered users and 22 guests
