 [ 6 posts ]
Fri Jun 04, 2010 6:50 am
Hello,
I've been having problems with my 580ex ii's going to sleep between shots and the cybersync's not activating them when I begin shooting again. I've been having to switch my flashes off and back on again to activate them. I thought the cybersync's would wake them back up. Any suggestions?
Bill
Fri Jun 04, 2010 8:54 am
There's two ways to keep the 580ex II from going to sleep on you. My choice is to put the 580ex II in slave mode as if I'm going to use Canon's E-TTL system. That makes the flash go to sleep after an hour, which matches the idle timeout of the Cybersync. You can also make the flash turn off after 10 minutes of inactivity in slave mode with custom function 10.
The other way is to turn off the auto-sleep mode on the flash altogether. Custom function 1 can be set to "1" to disable auto-sleep mode.
Fri Jun 04, 2010 9:24 am
The 580EXII will not wake up via the PC terminal or the Hotshoe (unless attached to the camera). This would be the case for virtually any radio remote. I would suggest turning sleep mode off, or extending the time out if that option is available. Incidentally, pressing the "Pilot" button wakes them without powering off.
Fri Jun 04, 2010 10:39 am
I would "second" Kurt's reply - Custom mode 1 to setting 1. Problem solved.
We have put a sticker on all our 580EXII flashes to remind folks that this is required for "strobist" use.
BUD at theSOPHA.com
Fri Jun 04, 2010 11:34 am
And... because Canon is Canon... the custom function on a 580EX is different than on the EXII... I think it's CF 14 on the 580EX.
Sat Jun 05, 2010 6:10 am
Thanks for the great info everyone. I'll be making these changes today!
 [ 6 posts ]
