Tue Dec 22, 2009 7:56 am
Hey PCB et al. I just got a set of CSR+ and Cyber Commander back from you after having problems with them. I assume they were loaded with the new patch that is due out real soon and I just wanted to say everything worked! I'm sorry if this will create a furry of "I want it now posts" but I did want to let you and everyone else know it worked.
The problems I was having;
CC would not start after battery change
CC freeze, lock up and/or lost communications with CSR+
ISO value not being saved or otherwise getting reset to 100ISO
All of these problems seemed to gone, and no new ones found in somewhat limited testing.
As a software developer I know what its like to get a something new and complicated to the market. If you guys succeed with only one quick patch you have done better than 90% of everyone else. Good job, great product.
Tue Dec 22, 2009 12:54 pm
Thanks for the feedback. We are glad you are enjoying the Commander! The firmware update should be available soon.
TS
Wed Dec 30, 2009 11:09 am
Any update on this Firmware release? I also have the black screen issue and popping out the memory card fixes it right now. I also have a fairly high miss fire rate (40-60% misses) and this is my second CC unit.
Thanks,
-Darrin
Wed Dec 30, 2009 11:45 am
we are working on the user update prceedures, which is somewhat different than initial installation.
TS
Wed Dec 30, 2009 12:02 pm
TS
Sounds good. Thanks for the update.
Happy Holidays.
-D
