| Cyber Commander Update http://paulcbuff-techforum.com/viewtopic.php?f=8&t=65 |
| Author: | Spiked [ Tue Dec 22, 2009 7:56 am ] |
| Post subject: | Cyber Commander Update |
Hey PCB et al. I just got a set of CSR+ and Cyber Commander back from you after having problems with them. I assume they were loaded with the new patch that is due out real soon and I just wanted to say everything worked! I'm sorry if this will create a furry of "I want it now posts" but I did want to let you and everyone else know it worked. The problems I was having; CC would not start after battery change CC freeze, lock up and/or lost communications with CSR+ ISO value not being saved or otherwise getting reset to 100ISO All of these problems seemed to gone, and no new ones found in somewhat limited testing. As a software developer I know what its like to get a something new and complicated to the market. If you guys succeed with only one quick patch you have done better than 90% of everyone else. Good job, great product. |
| Author: | Technical Support [ Tue Dec 22, 2009 12:54 pm ] |
| Post subject: | Re: Cyber Commander Update |
Thanks for the feedback. We are glad you are enjoying the Commander! The firmware update should be available soon. TS |
| Author: | dphotog [ Wed Dec 30, 2009 11:09 am ] |
Any update on this Firmware release? I also have the black screen issue and popping out the memory card fixes it right now. I also have a fairly high miss fire rate (40-60% misses) and this is my second CC unit. Thanks, -Darrin |
| Author: | Technical Support [ Wed Dec 30, 2009 11:45 am ] |
we are working on the user update prceedures, which is somewhat different than initial installation. TS |
| Author: | dphotog [ Wed Dec 30, 2009 12:02 pm ] |
Technical Support wrote: we are working on the user update prceedures, which is somewhat different than initial installation. TS Sounds good. Thanks for the update. Happy Holidays. -D |
