| Einstein 8.5 " Reflector Gel Mount? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=652 |
| Author: | OpticalWindows [ Mon Jun 14, 2010 10:00 am ] |
| Post subject: | Einstein 8.5 " Reflector Gel Mount? |
Is there an attachment to mount a gel onto the 8.5 inch reflector? |
| Author: | Liquid Rhino [ Mon Jun 14, 2010 10:35 am ] |
| Post subject: | Re: Einstein 8.5 " Reflector Gel Mount? |
any small clip or gaff tape should work. |
| Author: | Technical Support [ Mon Jun 14, 2010 11:03 am ] |
Agreed, if using our gels, i would probably use gaffers tape. This is due to the reflectors being slightly larger than the gels, and you can use the tape to mask the difference. If you opt for larger gels, bulldog or nylon clips available on our site should work. We do not offer anything more for gels for the 7" reflectors, as the Mainframe completely replaces any other reflector. http://www.alienbees.com/parts.html |
