Fri Jun 18, 2010 2:56 pm
Should I unplug the flashtubes and modeling lamps everytime that I travell? Or just putting the black cover plastic will be enough to protect it? Consider that I use Lowepro Computrekker Plus Rolling.
And also what is the best way for airline travel? Consider I use Hardcase with foam and checkin the hardcase to Special Baggage.
Thanks
Fri Jun 18, 2010 3:32 pm
The black cap should be enough, especially if using a hard case with foam. I would suggest always having at least one spare tube on hand in case something does happen. Also, it is not a bad idea to ensure the flash tube is fully seated before using the light after any suspected turbulent travel.
Users browsing this forum: No registered users and 81 guests
