| vagabond II charge loop problem http://paulcbuff-techforum.com/viewtopic.php?f=8&t=668 |
| Author: | cheptan [ Sat Jun 19, 2010 2:08 am ] |
| Post subject: | vagabond II charge loop problem |
hy, i'm from romania and i got this for about a mounth, its third or fourth time when i charge it, but this time it got into a loop when i plug the power cord on the cooling fan starting and the red led start to be on for about one second and then bouth shut down and then again starting to get on over and over...i have tryed to change the fuse but the same thing happen PS: i have done some measurements the inverter outputs 13.9 V that seems ok, the battery its only 11.3 V output maybe that is the problem..i guess i better buy another new one |
| Author: | Technical Support [ Mon Jun 21, 2010 2:50 pm ] |
| Post subject: | Re: vagabond II charge loop problem |
That does sound like an internal problem to the inverter, and would need to come in for repair. Please contact our Customer Service department to make arrangements to do that. |
| Author: | cheptan [ Wed Jun 23, 2010 3:10 am ] |
i have just got replaced the battery yestarday and all its back to normal,i found a new one here in romania, 12V 20 A..its the same like the original one :D (for about 40$) for the first 30 seconds when i plugged the cord the inverter was starting to go on and off, and suddenly it start to charge, this morning the battery seems so be fully charged I have done some tests with my AB800 at full power and everytihing is ok, for now |
