Mon Jul 05, 2010 8:57 am
Am I missing something?
How does one turn on the Cyber Commander?
I am holding it in my hand, inserted batteries properly.Read manual 3 times.
JImmy
Mon Jul 05, 2010 10:26 am
press any joystick in any direction. If, for some reason, that does not work, remove teh memory card and see if the unit turns on at that point. If so, the card may be corrupted and needs to be formatted.
Mon Jul 05, 2010 6:37 pm
ok...batteries were shot.Pnansonic..what can I say.
Put new Everraedy in....lights up like a charm.
BUT...display says ..."Cannot Read SD Card"
JImmy :o
Mon Jul 05, 2010 7:27 pm
OK...removed battery.
Removed original SD micro card.
Downloaded V29
Put existing card into computer cardreader.
Transfered Paul BUff folder to existing SD card
Put SD card into CC.
Put battery in.
CC was black screen.
Remover battery, remover existing SD card, reinstalled battery..voila..V29 on screen.
Put existin SD card into computer cardreader.
My computer/right clik on the sd card drive in my computer/clik format.
Format to FAT(default) which is FAT 16.
Took 2 seconds.Removerd battery from CC.Installed original reformatted SD card.Installed battery.
CC works fine.
Thanks
